Categorical Line Graph Settings (Legacy)
Line Graphs are easy to understand and are a great way to communicate important time-based trends, clustering, relative performance and outliers.
However, on occasion the axis is not time, but instead categorical. In this case a categorical line graph is used.
The categorical line graph settings pane is displayed after clicking the Options
button.
| Setting | Description |
| Dots Radius | Specifies the radius of each dot in pixels. |
| Show Borders | Determines whether a border is drawn around each dot. |
| Line Width | The line width. |
Other visualization-specific properties can be set by clicking on the Y-Axis variable drop area and then selecting the Y-Axis tab:
