Model Indexes Configuration Report
A Model Indexes report is one of the configuration reports provided by Monarch Server. This report lists all cases when mapping of Monarch Model fields does not correspond to Index Fields due to model changes subsequent to Document Type configuration.
If an exception is encountered, the report will display it in the following format:
ID NAME
101 Document Type Sample
Passenger field is mapped for Document Type Sample, but is not existing in current model.
To view, export, and print a Security configuration report
On the Navigation Tree, click System Reports and select Configuration.
Click the Model Indexes link. The Model Indexes report page is displayed.
- Choose between the following views:
Grid: The Grid view displays the report in tabular format. For each column, select any of the following operations by clicking
Sort Ascending: Select this option to arrange the entries in ascending order.
Sort Descending: Select this option to arrange the entries in descending order.
Columns: Select the columns to display in the grid view.
Set Column Position: Choose between Move Previous or Move Next to arrange the columns.
The following options are also available in Grid view:
Export to Excel: Select this option to export the report as an Excel Worksheet (*.xlsx).
Export to PDF: Select this option to export the report as a PDF file (*.pdf).
Search: Enter a keyword to perform a search within the entries.
Page navigation: Enter a page number or click the navigation arrows to switch pages.
X items per page: Choose the number of items to display from the dropdown menu.
Refresh: Click the Refresh button to display the most recent reports.
Report: The Report view displays the report in textual format. The following options are available:
Export to the selected format: Choose from among the following export format types that are listed in the dropdown menu: Acrobat (PDF) file, CSV (comma delimited), Excel 97-2003, Rich Text Format, TIFF file, and Web Archive. Click the Export button to complete the export process.
Print Preview: Click the Print Preview button
to view the report in printed format. -
Print: Click the Print button
at the top of the page, then click OK in the Print dialog.
NOTE: For information on how to convert a report to another format, see Converting a report to another format.
