Index Fields Report
A Index Fields report is one of the configuration reports provided by Monarch Server. This report includes all existing index fields, and provides the following information about them:
Names of index fields
Type of each index field (that is, string, number or date)
Limit (that is, the maximum length) for each string or number index field
To view, export, and print an Index Fields configuration report
On the Navigation Tree, click System Reports and select Configuration.
Click the Index Fields link. The Index Fields report page is displayed.
- Choose between the following views:
Grid: The Grid view displays the report in tabular format. For each column, select any of the following operations by clicking
Sort Ascending: Select this option to arrange the entries in ascending order.
Sort Descending: Select this option to arrange the entries in descending order.
Columns: Select the columns to display in the grid view.
Set Column Position: Choose between Move Previous or Move Next to arrange the columns.
The following options are also available in Grid view:
Export to Excel: Select this option to export the report as an Excel Worksheet (*.xlsx).
Export to PDF: Select this option to export the report as a PDF file (*.pdf).
Search: Enter a keyword to perform a search within the entries.
Page navigation: Enter a page number or click the navigation arrows to switch pages.
X items per page: Choose the number of items to display from the dropdown menu.
Refresh: Click the Refresh button to display the most recent reports.
Report: The Report view displays the report in textual format. The following options are available:
Export to the selected format: Choose from among the following export format types that are listed in the dropdown menu: Acrobat (PDF) file, CSV (comma delimited), Excel 97-2003, Rich Text Format, TIFF file, and Web Archive. Click the Export button to complete the export process.
Print Preview: Click the Print Preview button
to view the report in printed format. -
Print: Click the Print button
at the top of the page, then click OK in the Print dialog.
NOTE: For information on how to convert a report to another format, see Converting a report to another format.
