Adding a Schedule
A schedule is used to specify when, and at what interval the process will run.
To add a new schedule for a process
On the Schedule tab, click
Select the Suspended check box if you want to suspend the task.
Select the task execution frequency from the following options: One Time, Hourly, Daily, Weekly, Monthly, or Cron.
Set the time you want the process to run.
Set the start date of the process.
Select the appropriate timezone from the drop-down list.
Click the Save button, to save the schedule or Run Now to start the task immediately.
