Automator Process Dependencies
The Automator Process Dependencies Report is one of the Configuration Reports provided by Automator. This report presents which projects are used by which Standard Processes, which models are used by which projects, and which models and workspaces are used by which Visual Processes. It contains the following:
Process ID
Process name
Host name
Process type
Models used
Projects used
Workspaces used
To view, export, and print an Automator Process Dependencies Report
On the Navigation Tree, click System Reports and select Configuration.
Click the Automator Process Dependencies link. The Automator Process Dependencies report is displayed.
- Choose between the following views:
Grid: The Grid view displays the report in tabular format. For each column, select any of the following operations by clicking
Sort Ascending: Select this option to arrange the entries in ascending order.
Sort Descending: Select this option to arrange the entries in descending order.
Columns: Select the columns to display in the grid view.
Set Column Position: Choose between Move Previous or Move Next to arrange the columns.
The following options are also available in Grid view:
Export to Excel: Select this option to export the report as an Excel Worksheet (*.xlsx).
Export to PDF: Select this option to export the report as a PDF file (*.pdf).
Search: Enter a keyword to perform a search within the entries.
Page navigation: Enter a page number or click the navigation arrows to switch pages.
X items per page: Choose the number of items to display from the dropdown menu.
Refresh: Click the Refresh button to display the most recent reports.
Report: The Report view displays the report in textual format. The following options are available:
Export to the selected format: Choose from among the following export format types that are listed in the dropdown menu: Acrobat (PDF) file, CSV (comma delimited), Excel 97-2003, Rich Text Format, TIFF file, and Web Archive. Click the Export button to complete the export process.
Print Preview: Click the Print Preview button
to view the report in printed format. -
Print: Click the Print button
at the top of the page, then click OK in the Print dialog.
NOTE: For information on how to convert a report to another format, see Converting a report to another format.
