Altair® Panopticon™
Creating DolphinDB Input Data Source
The DolphinDB connector allows you to connect and query tables using DolphinDB java API.
1.      On the New Data Source page, select DolphinDB in the Connector drop-down list.
2.      Enter the following information:
Property
Host
DolphinDB host address.
Port
DolphinDB host port. Default is 8848.
User Id
The username used to connect to the DolphinDB service.
Password
The password used to connect to the DolphinDB service.
Check the Show Characters box to display the entered password characters.
3.      Enter the Query, which can contain parameters in a similar manner to the database connector.
6.     Click . The new data source is added in the Data Sources pane.
