Altair® Panopticon™
Creating Amazon Kinesis – Data Streams Data Source
The Amazon Kinesis – Data Streams connector reads records from the given data stream and Shard ID.
1.     In the New Data Source page, select Input > Amazon Kinesis – Data Streams in the Connector drop-down list.
2.     You can either:
·         select  the Use Default Credentials Chain check box to use the default Access Key ID and Secret Key Access, or
·         unselect the Use Default Credentials Chain check box and enter the Access Key ID and Secret Key Access
    NOTE
The Access Key ID and Secret Key Access from the AWS account can be configured in three places:
·         Two properties at the Streams.properties file which is available in the AppData folder of Panopticon Streams Server
o   connector.kinesis.datastreams.accesskeyid
o   connector.kinesis.datastreams.secretaccesskey
If this is the used configuration, the Use Default Credentials Chain box is not displayed in the connector UI.
This is the recommended way to provide the credentials.
·         AWS credentials provider chain
o   Environment Variables - AWS_ACCESS_KEY_ID and AWS_SECRET_ACCESS_KEY
o   Credential profiles file at the default location - ~/.aws/credentials on Linux, macOS, or Unix, and C:\Users\USERNAME\.aws\credentials on Windows.
·         Dedicated fields in the connector
Not the recommended configuration.
3.     Select or define the following properties:
Property
Region
Physical location of the data center. The list is picked up from the Amazon Kinesis Data Streams Endpoints and Quotas page.
Stream
Name of the stream from where you want to pull the data. Click Fetch Streams  to load all of the available streams from the AWS account.
Shard Id
Each connector instance or data source is connected to only one shard. Click Fetch Shards  to pull all of the shards from the selected stream.
From Beginning
The starting position in the data stream from which to start streaming. Default value is unchecked, which means LATEST. When checked, the starting position is set to TRIM_HORIZON.
   NOTE
All of the connection settings can be parameterized.
4.     Select the Message Type.
5.     Select either the dot (.) or comma (,) as the Decimal Separator.
   NOTE
Prepend 'default:' for the elements falling under default namespace.
6.      Click  to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
7.    You can also opt to load or save a copy of the column definition.
8.    Click  to add columns to the Amazon Kinesis – Data Streams connection that represent sections of the message. Then enter or select:
Property
Name
Fix Tag/JsonPath/Text Column Index/XPath
The Fix Tag/JsonPath/Text Column Index/XPath of the source schema.
Date Format
Enabled
Determines whether the message field should be processed.
   NOTE
To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them.
For example: yyyy-MM-dd HH:mm:ss.SSSSSS
To delete a column, check its  or all the column entries, check the topmost , then click .
9.   Define the Real-time Settings.
10.  Click . The new data source is added in the Data Sources list.
