Altair® Panopticon™
Viewing the Application Data Sources Usage
On the Applications tab, you can view the data sources that are currently used by an application.
1.     On the Applications tab, right-click on an application and select Data Source Usage in the context menu.
The list of data sources that is currently used by the application displays.
2.     Click .
