Altair® Panopticon™
Viewing and Managing Application Topic Usages
On the Applications tab, you can view the input and output topic usages of an application.
1.     On the Applications tab, right-click on an application and select Topic Usage in the context menu.
The <Application Name> Topics dialog displays.
If the application has been executed, the #Messages column will display the number of retrieved messages, while the Messages/sec column will display the number of retrieved messages per second.
If the application is not yet executed, both the #Messages and Messages/sec columns will display 0 values.
2.     You can then opt to:
·         clear data
·         clear schemas
·         sort topics
3.     Click Close.
