Altair® Panopticon™
Creating a JSON Input Data Source
The JSON connector allows the retrieval and processing of JSON files, either from a disk, a Text, or from a defined URL.
1.     In the New Data Source page, select Input > Json in the Connector drop-down list.
2.     Select the JSON File Source.
3.     Select either the period (.) or comma (,) as the Decimal Separator.
4.     Click  to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
5.     You can also opt to load or save a copy of the column definition.
6.     Click to add columns and specify their properties:
Property
Name
Json Path
The Json Path of the source schema.
Date Format
Enabled
Determines whether the message field should be processed.
To delete a column, check its  or all the column entries, check the topmost , then click .
7.     Click . The new data source is added in the Data Sources list.
