Altair® Panopticon™
Creating a REST Output Connector
Outputs an event to a REST API. This output connector can also be used as an alerting system.
1.     On the Data Source tab, select Output > Rest in the Connector drop-down list.
2.     Define or select the following properties:
Property
Authentication Type
·         Basic
Enter the URL of the REST API. Then enter the User Id and the Password that will be used to the connect to the REST API.
·         OAuth
Then enter the following settings:
o    Token URL – The URL to retrieve the access token from.
o    Token Request Body – The request body used for access token requests.
o    Add Access Token To - The Access token retrieved from the Token URL can be added to headers, URL or request body, depending on how the REST endpoint needs the token.
§  Request Header - A header is automatically added to the REST API request.
§  Request URL - The URL needs to be manually parameterised with a {access_token} parameter, before calling the REST API, the parameter is replaced with the actual token.
§  Request Body - The Request Body needs to be manually parameterised with a {access_token} parameter, before calling the REST API, the parameter is replaced with the actual token.
o   URL – The URL of the REST API.
HTTP Method
Select the appropriate HTTP method for the request from the following options:
·         GET – retrieve data
·         POST – add new data
·         PUT – replace existing data
·         DELETE – remove existing data
Content Type
The required Content Type. Default is application/x-www-form-urlencoded
Timeout
The length of time to wait for the server response (10 to 300). Default is 10.
Request Body
The Request Body for the HTTP POST.
3.     Click . The new data source is added in the Data Sources list.
