Altair® Panopticon™
Deleting Data Sources
Users with an Administrator or  Designer role can delete data sources using the toolbar or context menu.
1.     Select the check box of one or several data sources either on the Grid View or List View.
2.    Then select either:
·        the Remove  icon on the toolbar
·         Remove in the context menu
A notification message displays.
For a data source, the corresponding applications that will be impacted is listed:
For several data sources:
3.     Click  to remove.
