Altair® Panopticon™
Saving an Application
Saved applications (.app) are available in the PanopticonAppdata\CEP\Applications folder (i.e., c:\streamsserverdata\CEP\Applications).
1.     On the Application page, you can either click:
·         the Save   icon
·         the  icon. The context menu displays with three saving options:
¨         Save
Click to save the changes made in the application.
¨         Save as Copy
Click to make a duplicate of the application. The original name is appended with _Copy.
To change the Application Name, click on it to make it editable, then enter a new one and click .
   NOTE
The Name or ID must start with a letter (a to Z) or underscore. Also, it can only contain letters (a to Z), numbers (0 to 9), and underscores.
¨         Revert to Saved
Click to revert to the previously-saved application settings.
   NOTE
·           After saving, you can start the execution of the application. You can do this either in the Application page or on the Applications tab.
·           When saving an application, the color will indicate the status of the nodes:
o        Black – no issue
o       Yellow – no traffic on the topic
o       Red – there are definition issues. Refer to Validating and Fixing Application Issues for more information.
