Altair® Panopticon
[15] PCLI: Command Utilities for Panopticon Real Time
Panopticon Real Time is supplied with a command line utility PCLI.jar.
After extracting all of the contents of the pcli archive (pcli-java.zip), it is necessary to copy all of the JAR files from …\apache-tomcat\webapps\panopticon\WEB-INF\lib\ to …\pcli-java\lib\.
   NOTE
Ensure to overwrite any existing files when copying all of the JAR files from …\apache-tomcat\webapps\panopticon\WEB-INF\lib\ to …\pcli-java\lib\.
This supports the following:
clearcache
Clears the cache on a Panopticon Real Time.
plugins
Troubleshoot the plugins that this program utilizes.
publish
Publishes a workbook to a server or folder.
version
Prints program (and optionally server) version and exits.
help
Use ‘help <command>’ to get help on a specific command.
upgrade
Upgrades specified workbook to the newest version.
schemify
Updates workbook data tables with missing schema information.
exportdatasource
Export workbook data sources.
convertpermissions
Converts old permission files to the new format.
migratedatabasetojdbc
Migrates all usages of the Database connector to JDBC connector in the given workbook/directory of workbooks.
mockdata
Updates workbook data tables with mock data based on the stored schema.
encrypt
Allows encryption of either a single text or an entire .properties file.
decrypt
Allows decryption of either a single text input or an encrypted .properties file.
Summary help is displayed through: [pcli-java folder]>java –jar pcli.jar help
More detailed help is displayed through: [pcli-java folder]>java –jar pcli.jar help [command]
