Altair® Panopticon
Adding Parameters
Follow the steps below to add global parameters with an Administrator role.
1.     On the Parameters tab, click the Add  icon of a global folder (root or subfolder).
A new parameter entry displays.
2.     Enter a Name for the new parameter.
3.    Select the Type: Text, Numeric, or Time.
4.    Enter the Default Value.
   NOTE
·         You can enter several default values, separated by a comma.
·         Single quotes on parameter value/s are removed when saving global parameters.
·         For the Time type, the following formats for the default value are accepted:
o     "yyyy-MM-dd"
o     "yyyy-MM-ddTHH:mm:ss"
o     "yyyy-MM-ddTHH:mm:ss.SSS"
5.     Check the Encrypted box to encrypt the value.
   NOTE
Encryption is only supported for text parameters.
6.     Click . The new parameter is added in the list.
Global parameters added in the parent/root folder are inherited by the corresponding subfolders.
