Altair® Panopticon
Connector for SVG
The SVG connector can provide for:
q  Maps for Choropleth map visualizations (http://en.wikipedia.org/wiki/Choropleth_map).
q  Store plans for visualization of crowd flows, client interaction volumes, and so on.
q  Schematic drawings of process industry facilities for hardware performance monitoring.
The SVG XML is translated, and the rendering is done by  Panopticon Real Time. For this reason, Panopticon Real Time does not support the full scope of the SVG standard definition.
The only element supported is PATH: http://www.w3.org/TR/SVG/paths.html
This connector allows you to select the SVG File Source.
