Altair® Panopticon
Bookmarking
Bookmarks are saved configurations of the active dashboard and workbook. A bookmark can be added, by authenticating, and clicking on the Bookmarks icon.
Bookmarks are not available with anonymous access workbooks.
Bookmarks do not save data, but do save:
q  Dashboard
q  Parameters
q  Filters
q  Breakdowns, Hierarchies, Visible Depth, and Drill Level
q   Variables (Size, Color, X, Y, etc.).
Consequently, although the underlying data may change, a specific view of that data can be specified and bookmarked for future usage.
Bookmarks can be added and are available to all authenticated users of the workbook.
Bookmarks also generate a unique URL, which can be sent to another individual with access, allowing them to see exactly the same view of the selected dashboard.
New bookmarks can be added by clicking the New  button.
A new instance of the bookmark is added under the My Bookmarks section  in the Bookmarks pane. The bookmark is initially named <Workbook> - <Dashboard> - Bookmark<number>.
Click the Modify  icon to define the settings of the bookmark. The Bookmark Settings pane is displayed.
Property
My Bookmarks
User’s own bookmarks.
Shared Bookmarks
Bookmarks shared to the user.
Delete Bookmark
Remove the bookmark.
Click Yes on the notification message to delete the bookmark.
Search Bookmark
To search for a particular bookmark, enter it in the Search box. You can also enter one or more characters into the Search box and the suggested list of bookmarks that matched the entries will be displayed.
Modify Bookmark
Display the Bookmark Settings pane for the modification of the bookmark settings.
Update Bookmark
Update the bookmark settings.
Click Yes on the notification message to update.
Create Bookmark
Allows the creation of a new bookmark.
Close
Close the Bookmark Settings pane.
Name
Name of the bookmark.
Description of the bookmark.
Dashboard Parameters
Available dashboard parameters.
NOTES:
·         Excluding a parameter value sets its value in the bookmark to type Text and empty string value. This will allow the dashboard logic to dictate the parameter value that should be used when opening the bookmark.
For example, if the dashboard contains an Action Date Picker that defaults to now, and that same parameter value is excluded from the bookmark, then the Action Date Picker default value will be the value when the bookmark is opened.
·         Directly modifying the parameter value in the bookmark (such as entering now, today, or yesterday) is not supported.
Save
Enabled when a change is made in the bookmark settings. Click to save.
