Adding an Action Button
The action button control allows users to execute an action. It can also just pass the entered parameter value if the string is exactly equal to the {parameter-name}.
1. After double-clicking or drawing a rectangle on the dashboard canvas, click on the Select Part pane then click the Action Button icon.
The Action Button pane is displayed, and the Action Button part is added on the dashboard canvas.
2. Select any of the Action Modes:
· Set Parameters
The Parameters pane lists the available parameters to set the data loading for each interaction with the Action Button.
Click on a parameter instance to expand and set the values that the action requires.
· Navigate
Allows the selection of the dashboard where you want to pass the parameters.
· Execute Script
Allows the execution of a script.
Enter the parameterized Script.
The parameters are written within curly brackets, {ParameterName}.
For script actions allowing multiple value input, you can optionally specify a value separator within the curly brackets where you put the parameter name. The syntax is as follows:
{ParameterName:Separator}
For example: {Company:|}
Default separator is comma. At execution, the parameter will be replaced with real field values associated with the selected visualization node.
You can opt to add new parameters by clicking and define the parameter values that the action requires.
· Update Data
Allows data update (typically in a database) by passing parameters into a data query.
Click on a parameter instance to expand and set the values that the action requires. You can also opt to click to delete a parameter.
You can also opt to specify one or several existing parameters that will get a new value when the Update Data action is executed. You can do so by clicking on the Parameter Resets section.
Click on the parameter instance to expand and define its properties.
· Open URL
Allows access to a web page or file or even point to other resources on the web such as database queries and command output.
¨ Enter the parameterized URL.
For actions allowing multiple value input, you can optionally specify a value separator within the curly brackets where you put the parameter name. The syntax is as follows:
For example: {Company:+}
Default separator is semicolon. Specifying for example a plus sign allows you to do multi search term searches on Google, for example.
The easiest way to create parameterized URLs is to open an example web page and copy the URL. As an example, Yahoo Finance Key Statistics for Microsoft has the following web address:
http://finance.yahoo.com/q/ks?s=MSFT
If a parameter called Ticker has been set up in the data table, you can generate the URL by removing MSFT and replacing it with {Ticker}:
http://finance.yahoo.com/q/ks?s={Ticker}
¨ Select the Target area of the page where the output URL will be displayed.
¨ Click to add parameters to the output URL.
The title of the action button defaults to the selected action mode.
3. Enter the new Title of the action button.
4. Check the Enabled User Input box to allow the entry of parameter value that will be executed once the action button is clicked.
Then, select the parameter.
This will be displayed on the dashboard as:
5. Enter a description or useful information about the action button into the Tooltip box.
6. Tap the Show as Hyperlink slider to turn it on and display the layout style of the button to a hyperlink.
7. Tap the Display in PDF slider to turn it on and include the action button in the output PDF.
8. To modify the style settings of the action button:
· click the Background box to display the Color dialog and set the background color or enter the Hex color code
· click the Foreground box to display the Color dialog and set the foreground color or enter the Hex color code
· set the Font type, size, style (Bold and/or Italic)
9. Click the Save icon on the toolbar to save the changes.
When saved, the notification is displayed.
