Percentile
The selected percentile.
Percentile is the value of the P-th percentile of an ascending ordered data set containing N elements with values .
There are two steps to compute for Percentile.
1. Calculate the rank:
The rank is then split into its integer component k and decimal component d, such that ..
2. Use the formula below to calculate as:
Sample 1
Consider the ordered list of values 15, 20, 35, 40, 50. What is the 40th percentile of this list?
1. Calculate the rank of the 40th percentile as follows.
Thus, n=2.6, which gives us k=2 and d=0.6.
2. Calculate the value of the 40th percentile.
Thus, the value of the 40th percentile of the ordered list 15, 20, 35, 40, 50 is 29.
Sample 2
Consider the ordered list 1,2,3,4. What is the 75th percentile of this list?
1. Calculate the rank of the 75th percentile as follows.
N = 75/100(4-1) + 1 = 3.25
Thus, n=3.25, which gives us k=3 and d=0.25.
2. Calculate the value of the 75th percentile.
Thus, the value of the 75th percentile of the ordered list 1,2,3,4 is 3.25.
Sample 3
Given the following sample fields:
Number |
Arbitrary |
Negative Values |
Positive Values |
One |
Binary |
Currency |
Decimal |
1 |
3 |
-1 |
1 |
1 |
0 |
$1.00 |
1.01 |
2 |
2 |
-2 |
2 |
1 |
$10.00 |
2.02 |
3 |
1 |
-3 |
3 |
0 |
$100.00 |
3.03 |
4 |
0 |
-4 |
4 |
1 |
$1,000.00 |
4.04 |
5 |
-1 |
-5 |
5 |
0 |
$10,000.00 |
5.05 |
6 |
-2 |
-6 |
6 |
1 |
-$1.00 |
6.06 |
7 |
-3 |
-7 |
7 |
0 |
-$10.00 |
7.07 |
8 |
0 |
-8 |
8 |
-$100.00 |
8.08 |
9 |
0 |
-9 |
9 |
-$1,000.00 |
9.09 |
10 |
0 |
-10 |
0 |
$0.00 |
0.00 |
Sample fields.
The 50th Percentile value for each field in the table:
5.50 |
0.00 |
-5.50 |
4.50 |
1.00 |
0.00 |
0.50 |
4.55 |
5.50 |
0.00 |
-5.50 |
4.50 |
1.00 |
0.00 |
0.50 |
4.55 |
The results per field.
