Morphing Visualizations
You can morph a visualization by simply selecting the required resultant visualization from the available listing.
When used in combination with the copy and paste functionality, dashboards can be quickly created.
1. On the Dashboard and Workbook Settings
pane, click the Dashboard tab and then the
button.
The Morph pane displays.
2. Select the visualization to morph from the drop-down list.
The list of visualizations is enabled.
3. Select another visualization on the list.
The visualization is changed to the new one.
NOTE |
When morphing between visualizations with the same variables, there is no further configuration required. For example, from a Horizontal Bar Graph to a Vertical Bar Graph. However, when morphing between visualizations with different variables, the new visualization will need to be configured to include columns for empty variables. For example, when converting from a Pie Chart to a Scatter Plot, the X and Y axis must be defined. |
