Editing a Folder
To edit a folder
On the Navigation Tree, click Server Library and select Folders.
Click the name of the folder you want to edit or click anywhere on its row, and then click
Make the necessary changes. For details about how to change group parameters refer to Adding a Folder.
To the changes, click the Save button.
The system saves the modified model to the database and displays the updated Folders page, if the operation is completed successfully.
To assign folder to user groups, roles, or users
Select the folder you want to edit on the Folders page. Click the name of the folder you want to edit or click anywhere on the row, and then click .
Click the Rights tab. For more information, see Assigning Folder Access Rights.
