Deleting a Project File
To delete a project file from the list
On the Navigation Tree, click Server Library and select Projects.
Click
at the end of the row with the project file you want to delete. A dialog box appears. -
Click Delete to delete the project file from the list.
NOTES:
If a project file has the Locked status (
), it cannot be deleted. Unlock the project file first and then try again.
If a project file is being used in a process, it cannot be deleted. Instead, a warning message pops up: "There are objects that use this item: Processes: <Process Name>."
