Deleting a Model
You can delete a model from the system via the Models page.
NOTES:
You cannot delete a model if it is currently assigned to a document type. You must first remove it from the document type in order to delete it from the system.
If you assign another model to a document type, you will need to configure and run a Re-index maintenance task to re-index the archived documents. If you do not re-index them, Monarch Server users will not be able to retrieve them.
To delete a model from the list
On the Navigation Tree, click Server Library and select Models.
Click
at the end of the row with the model you want to delete. A dialog box appears. -
Click Delete to delete the model from the list.
NOTE: If a model has the Locked status (
), it cannot be deleted. First unlock the model and then try again.
