Adding a Search Group
To add a search group
On the Navigation Tree, click Report Warehouse, then click Document Retrieval and select Search Groups.
Click
on the Search Groups page. -
Search Group Name: Enter a unique name of a new search group.
Description: Optionally, enter any text defining the search group.
Available Searches: The searches from this pane may be assigned to the current search group. To add a search, drag it from the left pane to the right pane.
NOTE: You can search for a particular query by typing (part of) its name in the Filter by field and clicking Apply.
Assigned Searches: Displays the searches selected by an administrator for the current search group. To remove a search, drag it to the left pane.
To save a search group, click the Save button.
The system saves the new search group to the database and displays the updated Search Groups page, if the operation is completed successfully. -
To reset the values, click the Clear button.
To close the Search Groups page without saving, click Cancel. Keep in mind that no changes will be saved.
NOTE: If you assign a search to the current search group, the system automatically excludes it from the search group, which had contained it before. If you exclude a search from the search group, it will not appear in MSClient.
