Adding a Portlet Group
To add a portlet group
On the Navigation Tree, click Portlets, and then select Portlet Groups.
Click
on the Portlet Groups page. The Portlet Group page appears. -
Name: Enter a unique name of the new portlet.
Description: Optionally, enter any text defining the portlet.
Base Url: Provide the base URL of the portlets belonging to the current group.
NOTE: If you have already provided the full URLs for the portlets of the group, you can leave the Base Url field empty.
Layout size: Select a layout in which the portlets will be displayed for the user in the Server client application. Possible layouts range from 1x1 (1 item arranged horizontally x 1 item vertically) to 4x4 (4 items arranged horizontally x 4 items vertically).
Available Portlets: Contains the list of portlets from which you select those to be assigned to the current portlet group. To assign a portlet to the group, drag it from the left pane to the right pane or click the plus sign next to the portlet name.
Assigned Portlets: Contains the portlets that you assign to the current group. To remove a portlet from the group, drag it from the right pane to the left pane or click the minus sign next to the portlet name.
NOTE: The maximum number of portlets that can be assigned to a group is 16, which is limited by the maximum layout size 4x4.
Add All: Click to assign all available portlets to the current group.
Remove All: Click to remove all assigned portlets from the current group.
To save the new portlet group, click the Save button.
The system saves the new portlet group to the database and displays the updated Portlet Groups page. -
To reset the values, click the Clear button.
To close the Portlet Groups page without saving, click Cancel. Keep in mind that no changes will be saved.
