Adding a Custodian Schedule
After you specify job log disposition settings for a process, you need to specify a schedule for the Custodian, which is responsible for implementing the job log disposition settings. If you do not specify a schedule for the Custodian, the job log disposition settings will not be implemented.
To add a Custodian schedule
On the Custodian Schedules page, click the Add icon
On the displayed page specify the following settings:
Name: Enter the name you want to assign to the schedule.
Suspended: Select this check box to suspend the task.
elect the task execution frequency from the following options:One Time, Hourly, Daily, Weekly, Monthly.
In the At box, set the time you want the process to run.
In the On box, set the start date of the process.
Select the appropriate timezone from the drop-down list.
Click the Save button, to save the schedule or Run Now to start the task immediately.
NOTE: The Custodian schedule must be enabled for the job log disposition to occur at the specified time.
