Deleting a Model
You can delete a model from the system via the Models page.
To delete a model from the list
On the Navigation Tree, click Server Library and select Models.
Click
at the end of the row with the model you want to delete. A dialog box appears. -
Click Delete to delete the model from the list.
NOTE: If a model has the Locked status (
), it cannot be deleted. First unlock the model and then try again.
