Assigning Model Access Rights
The creator of a model automatically receives the rights to view and edit it.
You can assign model access rights to other users. Authorized users can view and edit models, assigned to them, in MSAdmin.
To assign model access rights
On the Navigation Tree, click Server Library and select Models.
Click the name of a model you want to assign access rights for.
On the displayed page, select the Rights tab.
Select Global check box for a model to be available to all users and click the Save button.
Otherwise proceed to the next steps. -
Click User Groups to expand a hidden section. Select user groups that you want to have access to the model.
To add a user group drag it from the left pane to the right pane or click
icon next to its name -
To remove a user group drag it from the right pane to the left pane or click
icon next to its name.
Note: You may also use Add All and Remove All controls.
Click Roles to expand a hidden section. Select roles that you want to have access to the model.
To add a role drag it from the left pane to the right pane or click
To remove a role drag it from the right pane to the left pane or click
In the Users section select users that you want to have access to the model.
To add a user drag it from the left pane to the right pane or click
To remove a user drag it from the right pane to the left pane or click
To apply the changes, click the Save button.
Note: If you don't specify any access rights for a model, then it will be available for all users.
