Adding a Change List
To add a change list
On the Navigation Tree, click Server Library, and select Change Lists.
Click
on the Change Lists page. The Change Lists page appears. -
Enter the name of a change list file in the Name field.
Enter the description of a change list in the Description field. This step is optional.
To enter the path to a change list file in the Change List field, click the Browse button, and select a change list file.
Enter any comments if necessary in the Comment field.
Assign the change list to a new or existing folder in the Assign to Folders field. To add the change list to a new folder, click Create New Folder.
To save a change list, click Save.
The system saves the new change list to the database and displays the updated Change Lists page, if the operation is completed successfully. -
To reset the recent changes, click the Clear button.
To cancel the operation and return to the Change Lists page, click the Cancel button.
To upload a change list
On the Navigation Tree, click Server Library and select Change Lists.
Click Upload Change Lists on the Change Lists page.
Click Add Files to browse to a change list file or drag and drop change list file in the Drop files here area.
