Select an ODBC Data Source Dialog
This dialog box allows you to select from a list of currently-defined ODBC Data Sources.
To access the Open Data Source dialog, select: Browse and then ODBC connection... from the Open Database dialog.
Options
Field |
Description |
Data Source List |
Displays a list of currently-defined ODBC Data Sources available from the Monarch Classic machine. For easy reference, the list includes the data source type and driver used. Select the source you want from this list. |
Use Trusted Connection (Windows Authentication) |
Click if you wish to use Windows Authentication. Otherwise, you need to provide a Login ID and Password. |
Login ID |
If you have are not using a trusted connection, enter the Login ID required by the ODBC data source. |
Password |
If you have are not using a trusted connection, enter the Password required by the ODBC data source. |
OK |
Click to accept the definition and close this dialog box. |
Cancel |
Click to cancel the open database definition and close this dialog box. |
Help |
Displays this help topic. |
