Joining Tables
The Combine Stage allows you to create joins from two tables in a single join session. Join two or more tables if you want to combine records from each table into a more comprehensive table. Joins allow you to consolidate your data and enrich your view of the information they contain.
Join condition
To be able to successfully join two tables, both tables must have a common field that you can use to join on, called a join key.
In the example above, we can join the Order table with the Order Details table on the join key OrderID.
Standard joins
Continuing the example, we join an Order and Order Details table and use inner join to create a new table that shows both the Shipping Address and Products ordered. You can then easily determine the quantity of products being shipped to each country or region.
Standard Joins (inner join, left outer join, right outer join, and full outer join) produce tables that show matching rows between two tables.
Negative joins
Monarch Data Prep Studio also supports negative joins or complements, wherein only records that have no match are displayed. This functionality is useful when you are trying to investigate reconciliation issues, and you want to easily look for problematic records.
For example, consider the following Employee tables:
Employee Table 1 (Left table)
Employee Table 2 (Right table)
A Left Negative Join will only show the records for the following Employees:
A Right Negative Join will only show the records for the following Employees:
Records for employee 1601562 (Jacobson) and 1598264 (Marshall) are not included in any Join Complement result as these employees have matching records in both tables.
To generate negative joins, select the appropriate icon from the Edit Join dialog when creating a join.
Joining tables
After loading data into the Prepare Window, click Combine > Join to activate the Joining Stage.
Do one of the following:
Drag a table from the table selector to the
drop box. -
Drop a table from a location on your machine (e.g., from your desktop or local/network drive) to the
drop box. -
Double-click on a table from the table selector to add it to the
drop box.
Select a second table following the same procedure in Step 2.
The tables you selected or dropped are displayed on the join work area:
If you wish to replace any of the tables in the join work area, hover over the table to be replaced and then click on the Remove icon.
Then, drag and drop a new table into the table drop box.
A preview of the data in the active table displays.
Select the Click to Join button.
The Edit Join dialog displays:
NOTE: This dialog can be maximized and returned to its original size by selecting the Maximize
and Restore
buttons located at the top right-hand corner of the dialog. You can resize further by using the resizing handle
located at the bottom right of the dialog.NOTE: If you want Monarch Data Prep Studio to analyze your two tables and recommend join keys use the Join Analysis feature to do so.
Set the Join Name. This will become the name of the resulting table.
By default, the Join Name is Join. Sequential default names are assigned to the Join result, i.e.: Join, Join(1), Join(2).
If you do not set a name at this point, you can rename the table in the Prepare Window at any time.
Select a Join Type from the drop down, and then the actual join operation.
To illustrate the join types and operations below, consider the following examples:
STANDARD JOINS
Join Operation
Inner Join
Select only rows from both tables for which the join keys match.
With the example above, the result will be:
Left Outer Join
Keep all rows from the left table. When there is no matching right row from the right table, empty values will be returned.
Right Outer Join
Keep all rows from the right table. When there is no matching values from the left table, empty values will be returned.
Full Outer Join
Keep all rows from both tables. When there is no matching values from either table, empty values will be returned.
NEGATIVE JOINS
Join Operation
Inner Negative Join
Keeps all rows from both tables that have do not have any matches.
With the example above, result will be:
Left Negative Join
Keeps all rows from the right table that have no match with records on the left table.
Right Negative Join
Keeps all rows from the left table that have no match with records on the right table.
LOOKUP
If you want to do only simple lookup, select a Lookup join type. To illustrate the lookup join types below, consider the following example (only keys are shown for simplicity):
Join Operation
Simple Left Lookup Join
Keeps all rows from the left table and matches only one row per value on the right table, even if there is more than matching row.
Note that only one record for right key value 002 is retained in the result, even if there are two records that have this key.
Simple Right Lookup Join
Keeps all rows from the right table and matches only one row per value on the left table, even if there is more than matching row.
Note that only one record for left key value 001 is retained in the result, even if there are three records that have this key.
Select the Join Keys.
Join keys are the columns that will allow you to match the rows in one table with the rows in another. For instance you can link an Order table with Order Details using Order ID as the join key.
To select join keys, select the key icon on the left table with the matching key icon of the matching column in the right table:
You must use two fields that have the same data type as join keys.
The join keys just selected are displayed above the column list:
If you wish to delete join keys, click on the Delete Join Key icon
beside the join key pair.Note that columns need not be of the same data type to be used as join keys. When columns with mismatching data types are used as join keys, Data Prep Studio automatically converts these columns into text to allow joining of the two tables.
Select or unselect the fields you want to included or exclude in the resulting table.
Click on the checkmark beside a field to include or exclude this in the result table:
You can also select other options to:
Select or deselect all columns
Select or deselect duplicate records.
If you want to be able to match more records, check Fuzzy Matching and set the fuzzy matching tolerance level.
Fuzzy Matching tries to match key values that are not 100% identical but similar.
For example, if you are matching on a column Item_Name (i.e., Item_Name_L and Item_Name_R are join keys), the following will match when Fuzzy Matching is enabled:
Item_Name_L
Item_Name_R
ROAD-750 BLACK
ROAD-75 BLACK
HL ROAD FRAME - RED
HLROAD FRAME - RED
TOURING REAR WHEEL
TOURING REAR WHEELS
ML TOURING SEAT ASSEMBLY
ML TUURING SEAT ASSEMBLY
MOUNTAIN-200 BLACK
MOUNTAIN 200 BLACK
Note that fuzzy join only works for key values that have a text data type.
Select OK to complete the join.
The new table is included in the table list. A join icon beside the new table's name indicates that this is the result of a combine operation. Also, the table that have been combined are displayed below the join.
If you want to join another table with the result, select another table and repeat the steps above.
If you want to transform the resulting table, go to the Prepare Window.
Monarch Data Prep Studio assigns sequential default names to the Join result, i.e.: Join, Join(1), Join(2). Rename the result as needed, following the steps in Renaming a Table.
If you want to edit or discard the join, select the corresponding option from the drop-down beside the Join table:
Analyzing joins
Monarch Data Prep Studio can analyze your two tables and recommend the best join keys to use.
The dialog then shows which join fields will produce the best results (the higher the percentage value, the more rows are joined by a join key combination). To determine the join field combination, hover over a percentage value:
In this example, the mouse is hovered over the box marked 65%. The pop-up notifies you that using Emp_ID from the Accounting table and Emp_ID from the Compensation table will produce a 65% match.
In the Edit Join dialog, select Recommend Keys.
The Join Analysis dialog displays:
You can play around with the analysis further. For instance, you can:
Select a different join type from the drop down and a different join operation to see if you get better join results.
Display the Options panel:
...to do the following:
Set a minimum match: Move the slider to control the percentage match that displays. For instance, you can ask Monarch Data Prep Studio to show only percentage matches 95% and above. Then you can click on the boxes that display to view which keys you need to join to produce those matches.
Zoom: Move the slider to make the boxes bigger for better readability. This functionality is helpful if there are a lot of percentages boxes that are displayed.
Left/Right Key filter: Enter key values to see if you get better matches if some values are suppressed.
If you are satisfied with a projected join result, click on the box reflecting this result to initiate the join. The Edit Join dialog displays once more.
Double-check your join and then click OK.
Creating new joins
If you would like to create a new join after completing a previous one, select the Create New Join
button located on the upper right-hand corner of the Combine Data Stage. Doing so removes all tables already placed in the joining stage, as well as the previous join defined. You can now begin creating a new join.
Creating multiple joins
Multiple joins in a single join session are supported in Monarch Data Prep Studio. If you would like to create multiple joins (e.g., join three tables into a single table), complete the join operation for the first two tables and then initiate another join operation to combine the resulting joined table with the third table. You can join as many tables as you wish following this process as long as the join condition stated above (i.e., the two tables have a common join key) is observed.
Related Links
