Function: LTrim
Removes leading spaces from a string.
LTrim(string)
Arguments
string can be a constant, a character field, an expression that results in a string or a function that returns a string.
Return value
This function returns a character string.
Calculated field example
If the Product field contained the value of "   chair", the following calculated field expression would return "chair": LTrim(Product)
Filter/Find example
Records with a Product field value of "    chair" or " chair" can be selected or found using the expression: LTrim(Product)="chair"
