Function: Dtoc
Converts a date to character format.
Dtoc(date[,date format])
Arguments
date can be a constant, a date field, an expression that results in a date, or a function that returns a date.
The optional date format parameter tells Monarch Classic how to interpret the date. Valid options for this parameter are:
  • "m/d/y"
  • "d/m/y"
  • "y/m/d"
The quotation marks are required.
The date format setting is useful when:
  • Reports contain dates in more than one format
  • You need to set the date to match or conform to regional settings
Return value
This function returns a string in the form MM/DD/YYYY.
Calculated field example
If the Ship_Date field contained a date of 1/2/2003, the following calculated field expression would convert it to a character string of 01/02/2003: DtoC(Ship_Date).
