Connector Dialog for HubSpot
NOTE: This connector requires a Java Virtual Machine (JVM) to work. If it is not available on the connectors list, follow these steps to enable it.
Enter values into the dialog box to connect and fetch data from your HubSpot data source. Select a specific tab to display specific options.
| Connection Tab | |
Fill out the fields below to initiate a successful connection. Bold fields are required. Other fields are optional but you may need to consult your data source administrator for other field values you need to enter to connect. On the connector dialog, hover your mouse over the field name to display a description or help about that field. |
Field |
Description |
Host Name |
Enter the host name portion of the HTTP endpoint to which you send requests. |
Client ID |
Enter the client ID key for your application when authenticating to REST endpoints with OAuth 2.0 enabled |
Client Secret |
Enter the client secret for your application when authenticating to REST endpoints with OAuth 2.0 enabled. Important: The client secret is a confidential value used to authenticate the application to the service. To prevent unauthorized access, this value must be securely maintained. |
Access Token |
Enter the access token used to authenticate to REST endpoints with OAuth 2.0 enabled. Typically, this option is configured by the application; however, in some scenarios, you may need to secure a token using external processes. In those instances, you can also use this option to set the access token manually. |
Refresh Token |
Enter the refresh token used to either request a new access token or renew an expired access token for OAuth 2.0 implementations. Important: The refresh token is a confidential value used to authenticate to the service. To prevent unauthorized access, this value must be securely maintained. |
Authorization URI |
Enter the endpoint for obtaining an authorization code from a third-party authorization service for OAuth 2.0 implementations. |
Token URI |
Enter the endpoint for retrieving access tokens when OAuth 2.0 authentication is enabled. |
Redirect URI |
Enter the endpoint to which the client is returned after authenticating with a third-party service when OAuth 2.0 authentication is enabled For some authentication flows, the REST service will redirect you to a third-party service for authentication. Once your credentials have been validated, the third-party service returns the client to an endpoint in the REST service to continue the session. The endpoint used by the third-party service is provided by the client and specified using the Redirect URI option. |
Scope |
Enter a space-separated list of OAuth scopes that limit the permissions granted by an access token. |
Reset Connection |
Check this box to reset the OAuath connection and fetch new access tokens. |
TEST CONNECTION |
Click to initiate a connection and test the values you have entered. If there are errors, messages will be displayed beside this button. Note: You can right-click on an error message to display a Copy button. Select the button to copy the error message. |
| Tables and View Tab | |
Tables and Views |
Allows you to load, and then select, the tables from your database by manually selecting from a list. To load tables and views via search and select:
Note: If you wish to add a duplicate column, select this column from the Add a duplicate column drop-down list provided.
To select a column: Check the boxes beside the columns you want to use. If you want to use all columns check the Column box on the header.
To aggregate columns:
If the data returned are to be aggregated, check the Aggregate box on the header, then select the aggregation method you want to use for each column. The following aggregation methods are possible for each data type:
To filter columns:
If the data returned are to be filtered, check the Apply Filter on the header. Then, for each column, select a filter method from the filter drop down and then enter the filter value in the Filter Value box. Note that some data sources require case-sensitive filter values. Refer to this list to check which data sources have case-sensitive filters. To load tables and views using an SQL Query, select the Query tab |
Preview Data |
Click to fetch data using the credentials and criteria you have specified. This allows you to confirm your connection, ensure you have connected to the correct table, check your query, and verify the information that will be loaded. Notes:
| Query Tab | |
Query |
Allows you to load, and then select, the tables from your database by entering a SQL Statement. If you already selected Tables and Views, this box is updated to show the corresponding SELECT * FROM TABLE query.
If you want to define the query, enter the SELECT, EXEC, and/or WITH statements to execute. Notes
Preview Data |
