Connector Dialog for Altair Monarch Report Warehouse
Enter values into the dialog to connect to and fetch data from your Altair Monarch Server library data source.
Options
Field |
Description |
Monarch Server Client URL |
URL used to connect to the Monarch Server. |
Username |
A valid Username for the Monarch Server. |
Password |
A valid Password required to log-on the data source. This password must match the User ID above. |
Connect |
Click this button after you have specified the Server, Username, and Password. After a successful connection, you select a report. |
Document Type Group |
Select a Document Type Group from the drop-down. The list depends on the access rights defined for the current user. |
Select a Document Type |
Select a Document Type from the drop-down. The list depends on the access rights defined for the current user, as well as the Document Type Group initially selected. |
Model |
Select the Model you want to use for the document. |
Report Date |
Allows you to set a Date Range. Only documents that fall within this date range will be returned. |
Report |
Displays a list of reports that meet the criteria defined above. Highlight the reports that you want to use. |
View |
Select the report view that you want to use. |
Summary Name |
Select the Summary that you want to be applied. The list displayed here depends on the Model and View that you selected above. |
