Appending Tables from the Prepare Window
From the Prepare Window, you can append tables by selecting them from the Table List (use Ctrl+click to select more than one table), right-clicking on your mouse, and then selecting an Append operation from the context menu that displays.
Note that:
Different options will produce different results.
In some cases, the order in which you select tables to append will affect the result.
Steps
In the Prepare window table list, select the tables you want to append. (Ctrl+click on the tables to select more than one table.)
Right click, select Append Tables, and the then select the append method:
Match Columns on Name
Match Columns on Name and Type
Match Columns on Order
Match Columns on Order, Name and Type
Note: If you want more control with defining the append, consider using the Edit Append dialog.
Examples: Appending Tables by Matching on Name
Example 1
Consider the following tables to append:
Data Processing Table
Dept |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Marketing Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
Matching Columns on Name produces the following result:
Dept |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
In this example, the Department column values of the Marketing and Accounting tables are not included because they do not match the name of the first column in the first table.
Note that Monarch Data Prep Studio will consider the first table as the basis for appending succeeding tables.
Example 2
If you append tables in a different order, i.e.:
Marketing Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
Dept |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
You get this result:
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Example 3
Note that the position does not matter when you append by Matching Columns on Name:
Marketing Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
Last Name |
First Name |
Emp ID |
Date |
Department |
Gender |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
Data Processing |
M |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
Data Processing |
M |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
Data Processing |
F |
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Examples: Appending Tables by Matching on Name and Type
When you Match on Name and Type, Monarch Data Prep Studio will append only tables with columns that have the same name and data type. This append follows the same logic as Matching in Name, but with the added condition that column data types match.
Example 1
Department |
Last Name |
First Name |
Emp ID (number) |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Marketing Table
Department |
Last Name |
First Name |
Emp ID (text) |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting Table
Department |
Last Name |
First Name |
Emp ID (text) |
Date |
Gender |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
The result will be:
Department |
Last Name |
First Name |
Emp ID (number) |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Marketing |
April |
Anne |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
12/18/2003 0:00 |
M |
Accounting |
Aldridge |
Jeff |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
6/4/2005 0:00 |
M |
In this example, the Emp ID column values of the Marketing and Accounting tables are not included because they do not match the data type of the Emp ID column in the Data Processing table.
Example 2
If you have the following tables:
Department |
Last Name |
First Name |
Emp ID (number) |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Marketing Table
Department |
Last Name |
First Name |
Emp ID (text) |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting Table
Department |
Last Name |
First Name |
Employee ID (number) |
Date |
Gender |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
The result will be:
Department |
Last Name |
First Name |
Emp ID (number) |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Marketing |
April |
Anne |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
12/18/2003 0:00 |
M |
Accounting |
Aldridge |
Jeff |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
6/4/2005 0:00 |
M |
In this example, the Emp ID column values of the Marketing and Accounting tables are not included because they do not match either the name or the data type of the Emp ID column in the Data Processing table.
Example: Appending Tables by Matching on Order
When you match on Order, Monarch Data Prep Studio will append only tables with columns that match on position. Monarch Data Prep Studio will ignore column names and data types.
Dept |
Last Name |
First Name |
Emp ID (number) |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Marketing Table
Department |
Last Name |
First Name |
Emp ID (number) |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
If:
The Department column of the Data Processing table has a different name, and
The Emp ID column of the Accounting table has a different data type (text instead of number)
The result will be:
Dept |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
In this example, all values of Emp ID from all tables are included since we are only matching on Order and Name.
Appending Tables by Matching on Order, Name, and Type
When you Match on Order, Name, and Type, Monarch Data Prep Studio will append only tables with columns that match on position, name, and type.
Example 1
Dept |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Marketing Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
If columns in all tables have matching data, types, Append Tables > Match on Order, Name, and Type result will be:
Dept |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
Note that Monarch Data Prep Studio will consider the first table as the basis for appending succeeding tables. If you append tables in a different order, i.e.:
Marketing Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
Dept |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
You get this result instead:
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Example 2
Dept |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
Marketing Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Marketing |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Marketing |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Accounting Table
Department |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Accounting |
Aldridge |
Jeff |
1592784 |
10/13/1995 0:00 |
M |
Accounting |
Daley |
William |
1587390 |
1/30/1993 0:00 |
M |
Accounting |
Georges |
William |
1596792 |
6/4/2005 0:00 |
M |
If:
The Emp ID columns of the Accounting table has a different data type (text instead of number)
An Append > Matching on Order, Name, and Type result will be:
Dept |
Last Name |
First Name |
Emp ID |
Date |
Gender |
Data Processing |
Bass |
Andrew |
1593211 |
3/18/1999 0:00 |
M |
Data Processing |
Bittner |
Herb |
1597596 |
3/18/2005 0:00 |
M |
Data Processing |
Bittner |
Martha |
1604193 |
12/18/2001 0:00 |
F |
April |
Anne |
1597429 |
10/23/1993 0:00 |
F |
Banning |
David |
1607768 |
12/18/2003 0:00 |
M |
Aldridge |
Jeff |
10/13/1995 0:00 |
M |
Daley |
William |
1/30/1993 0:00 |
M |
Georges |
William |
6/4/2005 0:00 |
M |
Related Links
