Advanced Text to Number
Converts a combination of numeric and text field values into a corresponding numeric value, using the text prase as a numeric multiplier.
For instance:
If K is defined as a Factor of 1000, 2K is converted to 2000.
If M is defined as a Factor of 1,000,000 3.5M is converted to 3,5000,000.
NOTE: You can define a new Phrase and Factor combination using the Advanced Text to Number dialog:
The factoring is automatically applied when you select OK.
Input/Output Data Type
Input |
Output |
text |
Number |
In this example, Sale is the original text column and Sale - Converted is the converted column.
