Adding and Editing Bookmark Comments
Monarch Classic allows you to add and edit bookmark comments, also known as annotations. After adding an annotation to a bookmark, you or others can view the annotation by hovering the mouse pointer over the bookmark.
Adding bookmark comments
  1. In Report View, select a line that you want bookmarked.
  2. Do one of the following:
    • Right click and select Add Bookmark... from the context menu
    • Select Bookmark on the  Report View ribbon.
    The Add Bookmark dialog displays.
  3. In the text field, enter the desired comment or make the desired edits to the existing comment. You can specify that you want Monarch Classic to prompt you for a comment whenever you add a bookmark by selecting the Show When Adding Bookmarks check box.
  4. Click the OK button to close the dialog.
Your bookmark is added, and a small blue rectangle is displayed on the left side of the report line.
To view the bookmark comment, hover your mouse pointer over the bookmark in the line selection area.
Editing bookmark comments
  1. In the Report window, right-click on the line that is bookmarked.
  2. Select Edit Bookmark... from the context menu. The Bookmark Comment dialog displays.
  3. In the text field, enter the desired comment or make the desired edits to the existing comment. You can specify that you want Monarch Classic to prompt you for a comment whenever you add a bookmark by selecting the Show when adding check box.
