The variables for the material update parameters are:
E  |
Young’s Modulus  |
YS  |
Yield Stress of material  |
Strength coefficient (power law equation   |
Pre-strain coefficient  |
n  |
Strain-hardening exponent (measures stretch ability/work hardening of material)  |
r  |
Plastic strain ratio (measures deep draw ability of material)  |
Note: Material units must be consistent for all parameters.
The following equations are commonly used to calculate
 and
Where:
e = 2.718
TS = tensile strength
YS = yield stress
Some common unit conversions are listed below:
USCU – SI  |
SI - USCU  |
Length  |
1 in = 25.4 mm  |
1 mm = 0.03937 in.  |
Force  |
1 lb = 4.448 N  |
1 N = 0.2248 lb  |
Stress  |
1 Ksi = 6.895 Mpa  |
1 Mpa = 0.145 Ksi  |
Mass  |
1 lbm = 0.4536 kg  |
1 kg = 2.205 lbm  |
Gravity  |
