The load command is used to read the data from either the grid file or an existing HyperXtrude save file:
load filename filetype {problem type}
Fresh start  |
Restarted run  |
filename  |
grid file name  |
save file name  |
filetype  |
phlex  |
restart  |
Problem Type can be either one of the following: Metal Extrusion, Metal Rolling, or Polymer Processing.
