Manufacturing Solutions includes an interface with a HyperWeld user profile and FrictionStirWelding sub-profile. This interface provides tools to create the required data to set up and solve a friction stir welding problem.
Note: The FrictionStirWelding sub-profile shares the same solver with the HyperXtrude user profile. In addition to this online help, a set of tutorials is available to learn the interface for the HyperXtrude solver.
Data generated for a friction stir welding analysis is organized into .grf and .fsw or .tcl files:
.grf files  |
The.grf file contains the mesh, material data, boundary conditions, and other special data.  |
.fsw or .tcl files  |
The .fsw file, known as a parameter file or .tcl file, contains commands written in the TCL language to set process parameters and control the solver operations. This file can be saved with either a .fsw or .tcl extension.  |
Create Mesh
| • | Create Weld mesh model |
| • | Assign materials to components |
| • | Assign boundary conditions |
| • | Assign process parameters |
Material Database
| • | Add/edit/delete materials |
| • | Graph flow stress/viscosity |
Boundary Condition Editor
| • | Create/delete boundary condition data |
| • | Create loads for each BC |
Additional Tools
| • | Edit process parameters |
| • | Edit extract points |
| • | Inspect model summary |
| • | Split tet4 to hex8 |
Data Import and Export
See Also:
Friction Stir Welding User's Guide
