Below is a summary of the content of an input deck for a One-Step analysis. Each card is defined in its rigid format form and is shown as a number of fields with a length of 10.
In the following listings:
| • | The Type is the variable type and is either F, for floating point, I for an integer, or C for a character. The default gives the value set if the field is left blank or the card is not defined. |
| • | Any variables used for property ID as keywords should be positive and defined in the corresponding property card, which will share the same color. |
| • | Any card in italic is optional. |
The @HyperForm line is the first line of the file, in the parameter section.
The following cards appear in the bulk data section, between "Begin Bulk" and "ENDDATA".
PARAM
Variable |
Type |
Default |
Description |
COEFF  |
C  |
N/A  |
Coefficient of friction on the curvature.  |
MU  |
F  |
0.1  |
The value of the coefficient of friction on the curvature. It should not be negative.  |
GRID
Variable |
Type |
Default |
Description |
G  |
I  |
none  |
Grid point identification number  |
CP  |
I  |
0  |
Coordinate system ID in which grid point is defined  |
X1, X2, X3  |
F  |
none  |
Location of the grid point in the coordinate system  |
CD  |
I  |
0  |
Coordinate system Id in which the displacements, DOFs, constraints and defined at the grid point  |
PS  |
F  |
none  |
Permanent single point constraints associated with the grid point  |
CTRIA3
Variable |
Type |
Default |
Description |
EID  |
I  |
none  |
Element ID  |
PID  |
I  |
none  |
Property ID of PHFSHL entry  |
G1  |
I  |
none  |
Grid point ID  |
G2  |
I  |
none  |
Grid point ID  |
G3  |
I  |
none  |
Grid point ID  |
CQUAD4
Variable |
Type |
Default |
Description |
EID  |
I  |
none  |
Element ID  |
PID  |
I  |
none  |
G1  |
I  |
none  |
Grid point ID  |
G2  |
I  |
none  |
Grid point ID  |
G3  |
I  |
none  |
Grid point ID  |
G4  |
I  |
none  |
Grid point ID  |
PHFSHL
Variable |
Type |
Default |
Description |
PID  |
I  |
none  |
Property ID of a PHFSHL entry  |
MID  |
I  |
none  |
Material ID  |
T  |
F  |
none  |
Thickness of PHFSHL  |
BHID  |
F  |
none  |
Blankholder ID  |
BDRID  |
I  |
none  |
Flag for curved binder  |
FLDID  |
F  |
none  |
Forming limit curve ID  |
MATHF
Variable |
Type |
Default |
Description |
MID  |
I  |
none  |
Material ID  |
E  |
F  |
none  |
Young’s Modulus  |
NU  |
F  |
none  |
Poisson’s Ratio  |
Y  |
F  |
none  |
Yield stress  |
K  |
F  |
none  |
Strength coefficient  |
n  |
F  |
none  |
Strain-hardening component  |
EPS0  |
F  |
none  |
Pre-strain coefficient  |
FLD0  |
F  |
none  |
The lowest point on the failure curve  |
R0, R45, R90  |
F  |
none  |
Lankford coefficients  |
FLDATA
Variable |
Type |
Default |
Description |
FLDID  |
I  |
none  |
E1  |
F  |
none  |
Minor strain value  |
E2  |
F  |
none  |
Major strain value  |
BLKHDF
Variable |
Type |
Default |
Description |
BHID  |
I  |
none  |
Blankholder ID  |
MU  |
F  |
none  |
Coefficient of friction. It should be positive.  |
FORCE  |
F  |
none  |
Blankholder force  |
Toggle  |
F  |
none  |
Flag assigned based on option (pressure/tonnage force)  |
EDGEBH
Variable |
Type |
Default |
Description |
EID  |
I  |
none  |
Element ID  |
S1, T1  |
F  |
none  |
Parametric coordinates of the entry points for the line |S1,T1|<=1.0  |
S2, T2  |
F  |
none  |
Parametric coordinates of the exit points for the line |S2,T2|<=1.0  |
FORCE  |
F  |
none  |
Blankholder restraining force  |
SID  |
I  |
none  |
Blankholder set Id for retrieving the deck back to HyperForm. It is not used in the solver.  |
EDRAWB
Variable |
Type |
Default |
Description |
EID  |
I  |
none  |
Element ID  |
S1, T1  |
F  |
none  |
S2, T2  |
F  |
none  |
FORCE  |
F  |
none  |
Drawbead restraining force, N/mm  |
SID  |
I  |
none  |
Drawbead set ID for retrieving the deck back to HyperForm. It is not used in the solver.  |
MPC
Variable |
Type |
Default |
Description |
SID  |
I  |
none  |
Set ID  |
G  |
I  |
none  |
Grid ID  |
A1, A2  |
F  |
none  |
Slope coefficient  |
SPC
Variable |
Type |
Default |
Description |
SID  |
I  |
none  |
Set ID  |
G1, G2  |
I  |
none  |
Grid ID  |
C1, C2  |
F  |
none  |
Constraint type 1: constraint in X-axis  |
D1, D2  |
F  |
none  |
Displacement  |
