The following table lists the items that may appear in the Details tab along with descriptions for each. The items that appear in the tree depend on the active process type. Complete details about LS-DYNA settings can be found in the LS-DYNA user manuals.
Control: |
Description |
Memory  |
Termination time  |
The termination time for the job.  |
Timestep  |
CyclesPerTravel counts the number of explicit time steps taken per unit of tool motion; DT2MS is a user-defined time step size for a mass-scaled solution.  |
d3plot  |
Count: Number of d3plot files to be written. Period: Interval between each d3plot file. Distance to BDC: Distance from the bottom dead center of the moving tool when d3plot files are written out.  |
ASCII Output  |
Whether to generate the LS-DYNA ASCII output files.  |
Adaptivity  |
Whether to use adaptivity  |
Summary: |
Description |
Motion Summary |
Displays a graph of time versus velocity of the parts.  |
Force Summary |
Displays a graph of the time versus force of the parts.  |
Blank1: |
Description |
Component |
The HyperForm component that corresponds to the blank.  |
Type |
Material Type |
Whether the material is from the materials database or a rigid.  |
Material: Name |
Displays name of the material that was selected from the materials database. (Database type only)  |
Material: Thickness |
The thickness value of the material. (Database type only)  |
System: |
Global or local system.  |
Material: Constraints: Translation |
Fixed, free, or along an axis.  |
Material: Constraints: Rotation |
Loads |
Contacts |
Position: Clearance |
The distance between the die and blank at the initial configuration for single action draw, double action draw and double action draw with support. Ignore the blank clearance for triple action draw.  |
Adaptivity |
Whether to use adaptivity.  |
Write State File |
Whether LS-DYNA should create the state file.  |
Die: |
Description |
Material: Name |
Displays name of the material that was selected from the materials database. (Database type only).  |
Material: System |
Loads: Load Motion |
Load Motion: Type |
Velocity Curve |
Contacts: Friction |
Coefficient of friction.  |
The distance between the die and the blank at the initial configuration.  |
Punch: |
Description |
Component |
The HyperForm component that corresponds to the punch.  |
Type |
Material: Type |
Material: Name |
Material: System |
Load Motion: Velocity Curve |
Displays a graph of time versus velocity.  |
The distance between the punch and the blank at the initial configuration.  |
Binder: |
Description |
Component |
The HyperForm component that corresponds to the binder.  |
Material: Type |
Material: Name |
Material: System |
Load Force: Force Curve |
Displays a graph of time versus force.  |
Load Stopper: Max disp |
Upper displacement limit for binder.  |
Load Stopper: Min disp |
Lower displacement limit for binder.  |
Load Stopper: Max vel |
Maximum velocity limit for binder.  |
Support: |
Description |
Component |
The HyperForm component that corresponds to the support.  |
Material: Type |
Material: Name |
Material: System |
Loads: Load Force: Force Curve |
Loads: Load Stopper: Max disp |
Upper displacement limit for the support.  |
Loads: Load Stopper: Min disp |
Lower displacement limit for the support.  |
Loads: Load Stopper: Max vel |
Maximum velocity limit for the support.  |
The distance between the support and the blank or die at the initial configuration.  |
