Find symmetrical surfaces or compare selected surface sets for symmetry. You can
        reorganize found symmetric surfaces into separate components or delete one subset of a pair
        of symmetric surface sets.
        This can be helpful with highly symmetrical components,
            because you can then perform geometry cleanup on only one half, mesh it, and then mirror
            the mesh instead of having to clean up the entire component prior to meshing
                From the Geometry ribbon, click the arrow next to the
                        Cleanup tool set name and select
                        Find Symmetry.
The Find Symmetry dialog opens.
                Select an action.
                            - Find symmetry
                            - Locate surfaces within a single component that are mirror images of
                                one another across a plane of symmetry that you specify.
                            - Compare
                            - Find symmetric surfaces among different components that you
                                select.
                Select surfaces.
                Define your axis of symmetry by selecting a vector entity and a base
                    node.
                Select a result.
                            - Reorganize
                            - Organize the symmetric surfaces into new, separate component.
                            - Delete Positive
                            - Delete the symmetric surfaces on the positive side of the symmetry
                                axis. Used when finding symmetry.
                            - Delete Negative
                            - Delete the symmetric surfaces on the negative side of the symmetry
                            - Delete First
                            - Delete the symmetric surfaces from the first set of selected
                                surfaces. Used when comparing symmetry.
                            - Delete Second
                            - Delete the symmetric surfaces from the second set of selected
                Click Apply.
