Boundary Conditions Menu
The following boundary condition tools are available:
        - Auto-Contact
 - Quickly and easily create one or more contact interfaces at once between several parts of your model. This tool is only available when the OptiStruct user profile is loaded.
 - Card Editor
 - Select the entities that are viewed in the card image subpanel.
 - Constraints
 - Place constraints or enforced displacements on a model.
 - Contact Surfaces
 - Create and modify contactsurf entities.
 - Contour Loads Utility
 - Create contour plots of applied loads and boundary conditions contained within load collectors.
 - Delete
 - Delete data from a model database, preview and delete empty collectors and preview and delete unused property collectors, material collectors, or curves.
 - Equations
 - Create, review and update equations.
 - Flux
 - Apply concentrated fluxes to your model.
 - Forces
 - Create concentrated forces.
 - Interfaces
 - Create and modify interfaces.
 - Line Loads
 - Allows total loads (forces and moments) to be applied in a distributed manner on nodes even though the load is applied on geometry lines or set of nodes forming ordered edges.
 - Loads on Geom
 - Map loads or boundary conditions from geometrical entities (loads on geometry) to the associated FE mesh entities (loads on mesh).
 - Loads Summation
 - Creates a summary of the loads (node-based forces or moments and element-based pressures) applied to a model.
 - Moments
 - Create concentrated moments.
 - Organize
 - Allows you to (re)organize your database by copying or moving data (entities) among collectors or includes.
 - Pressures
 - Create concentrated pressures.
 - Renumber
 - Renumber entities.
 - Systems
 - Create rectangular, cylindrical and spherical coordinate systems.
 - Temperatures
 - Create temperature constraints.
