Shrink Wrap Panel
Use the Shrink Wrap panel to generate an enclosed volume or solid mesh, and is typically used to approximate and simplify an existing model.
Shrink wrap can be generated using two algorithms: Loose or Tight. These determine
                how closely the resulting mesh adheres to the details of the underlying model, and
                are best suited to different use cases which will vary for any given use. In both
                wrap types, the steps necessary to generate a shrink wrap are identical.
- Loose Shrink Wrap
 - Generate a loose-fitting shrink wrap mesh that generally conforms to the model.
 - Tight Shrink Wrap
 - Generate a tight-fitting mesh that adheres closely to the underlying model, capturing as many features as possible.
                            ![]() Figure 1. Coarse STL Mesh Used as Input  |
                            ![]() Figure 2. Shell Mesh Wrapped Around the Original STL Mesh  |
Panel Options
| Option | Action |
| entity selector | Select entities to wrap. |
| features | Select feature lines
                                    on the model that must be retained. When meshed, elements will
                                    not cross over these lines.![]() Figure 3.  |
| tight wrap / loose wrap |
 Note: Not available when wrapping nodes or points.
| patch holes | If your model contains
                                    holes that you wish the shrink wrap to cover over as if they did
                                    not exist, enable the patch holes checkbox, and enter the
                                    sub-options accordingly.
                                    points.
| element size = | Specify the target
                                    element size for the shrink wrap mesh.  Note: Actual
                                        element size will vary depending on the model's features in
                                        order to improve mesh quality.
| generate solid mesh | Create the shrink wrap as a solid mesh rather than a shell mesh. This results in a mesh with no void space inside, rather than a hollow "bag" of mesh around the geometry. |
| mesh orientation: global system /local system | Choose whether to
                                    orient the mesh according to the global coordinate system, or a
                                    local one. This can strongly affect how the mesh follows the
                                    underlying geometry.![]() Figure 6. Shrink Wrap Output Using Global System . The mesh pattern runs diagonally across the pipes in the foreground. ![]() Figure 7. Shrink Wrap Output Using Local System. The mesh pattern is well aligned with the pipes in the foreground.  |
Command Buttons
| Button | Action |
| mesh | Create the new shrink wrap mesh according to the input values. |
| reject | Undo the most recent shrink wrap mesh creation. |
| features | Open the Features panel, where you can define feature lines in the model that should be preserved during the meshing process. |
| return | Exit the panel. |
