Gauge Panel
Use the Gauge panel to create design variables (DESVAR) and property relation (DVPREL1) cards for shell and composite laminate components (PSHELL, PCOMP, and PCOMPG) selected for size optimization.
Note: Only available in the OptiStruct solver interface.
Use this panel when several shell or composite components have the same or different shell thickness, ply thickness, or ply angle, and size optimization is performed with the shell thickness, ply thickness, or ply angle as the design variable.
Create Subpanel
| Option | Action |
| value from property / initial value |
| lower bound / lower bound % |
| upper bound / upper bound % |
| props | Select the property. |
Note: You can input actual values for lower bound and upper bound, or
                    select a percentage (%) of the initial value. For example, if the initial value
                    = 10, lower bound % = -20, and upper bound % = 20, then after exporting the file
                    the lower bound and the upper bound are automatically changed to 8 and 12,
                    respectively.
            Update Subpanel
| Option | Action |
| desvar | Specify a name for the design variable. |
| type | Select an entity type. |
| minimum thickness | Specify the minimum thickness or select zero to be the minimum. |
| maximum thickness | Choose to use the thickness value from the selected property, or enter a thickness value. |
Parameters Subpanel
| Option | Action |
| minmemb off / mindim = | Specify a value for the member size control, or toggle the switch to off. |
| stress constraint | Specify a value for the stress constraint, or toggle the switch to none. |
| fatigue constraint | Specify a value for the fatigue constraint, or toggle the switch to none. |
Composites Subpanel
| Option | Action |
| laminate thickness: min thickness = /off | Specify a value for the laminate thickness minimum, or toggle the switch to off. |
| laminate thickness: max thickness = /off | Specify a value for the laminate thickness maximum, or toggle the switch to off. |
| ply thickness: no. of constraints | Specify the number of constraints for the ply thickness. |
| ply percentage: no. of constraints | Specify the number of constraints for the ply percentage. |
| balance: no. of constraints | Specify the number of constraints for the balance. |
| constant: no. of constraints | Specify the number of constraints for the constant. |
Pattern Grouping Subpanel
| Option | Action |
| pattern type | Select the pattern type. |
| anchor node | Select the anchor node. |
| node id / coordinates | Choose to manually enter the ID for the node, or specify the coordinates of the node. |
| first node | |
| second node | Used for 2-plns sym or 3-plns sym types. |
| ucyc | Specify the number of repetitions in 360 degrees. Used for cyclic or cyc 1-pln types. |
Pattern Repetition Subpanel
| Option | Action |
| main / secondary / none | Determine whether you are establishing a main coordinate system, a secondary design variable, or neither. |
| system /coordinates | Choose to manually enter the values for the coordinate system, or to graphically select the system. |
| global system / local system | Reference coordinate system |
| anchor | Select the anchor node. |
| sx /sy /sz | x, y and z scale factors. |
Command Buttons
| Option | Action |
| create | Create the design variable. |
| edit | Opens the property collector panel to edit the property. |
| reject | Revert the most recent changes. |
| review | Review the load in the graphic area. |
| update | Update the load with the most recent changes. |
| return | Exit the panel. |
