Dependency Panel
Use the Dependency panel to find nodes that have their degrees of freedom removed by a constraint or MPC (multiple point constraint) more than once. By identifying and correcting such dependencies prior to solving, solution errors can be avoided.
                            ![]() Figure 1. Before  |
                            ![]() Figure 2. After  |
Note: Nodes that have multiple constraints or MPCs are
                    placed on the temporary node mark. However, nodes with multiple constraints or
                    MPC's can cause solution errors in many solvers. Every situation should be
                    evaluated and corrected accordingly. In the case of rigid elements, often
                    swapping the independent and dependent nodes of the elements, or moving the
                    constraints to the independent nodes, will correct the problem.
Panel Options
| Option | Action |
| entity selector | Select the entities
                                    you wish to check for dependencies. Use the switch to change
                                    between components and elements.  When you select elems, click
                                        the switch to change the selection mode.
| dependency | Perform the check and highlight any nodes in the selected entities that have multiple constraints or MPC's. |
| face angle / individual selection |
