Renumber Panel
Use the Renumber panel to renumber entities. You may also enter a value by which to offset the IDs of entities.
When the ID to be assigned to an entity is already assigned to another entity, MotionView adds the increment to the ID until a unique ID is found. Because of this, it may be necessary to move the entities out of the way by initially renumbering all of the entities starting with a large ID, and then renumber again with the desired IDs.
All Subpanel
| Option | Action |
| start with = | Specify the starting ID for the entities you selected. |
| increment by = | Specify the value by which to increment the entity IDs. |
| offset = | Specify the value with
                                    which to offset the selected entities.  It is possible to offset by both positive and negative values, provided that the offset IDs of all selected entities are greater than zero.  |
Command Buttons
| Button | Action |
| renumber | Renumber the selected entities according to the input settings. |
| min/max | Causes the total
                                    number and the range of numbers of the selected entity type to
                                    display as a message in the status bar. If entities are
                                    selected, the total number and range of numbers includes only
                                    the selected entities; otherwise, all entities of the type
                                    specified by the entity switch are counted. Note: Available in
                                        the Single subpanel.
| offset | Offset the numbers by the value specified in offset = each time you click offset. |
| reject | Undo the renumbering of entities. |
| return | Exit the panel. |
