Springs Panel
Use the Springs panel to create spring elements.
A spring element is an element created in a space between two nodes of a model where a spring connection is desired. In Radioss, three noded or four noded springs can be created.
Spring elements store a property and a degree of freedom (DOF).
Spring elements are element config 21 and are displayed as a line between two nodes with the letter K written at the centroid of the element.
Springs can translate to CELAS2 in Nastran or *SPRING in Abaqus.
Create Subpanel
| Option | Action |
| node 1 |
                                     Select the first end of the spring element.
                                ![]() Figure 1.  |
| node 2 |
                                     Select end b of the spring element.
                                Note: Once you select
                    both end a and end b, MotionView creates the spring
                    element.
![]() Figure 2.  |
| no vector / orient vector |
| dof1 - dof6 | Select the degree of freedom (DOF) that applies to the element. |
| property | Select a property to which the entity should point. |
Update Subpanel
| Option | Action |
| node 1 |
                                ![]() Figure 3.  |
| node 2 |
                    element.
![]() Figure 4.  |
Spring2, Spring3, Spring4 Subpanel
| Option | Action |
| node | Select the nodes to
                                    create spring elements between.  In the Spring3 subpanel, use the third node selector to select the direction node.  |
| orientation | Choose a method for
                                    orienting springs in 3D space.
Command Buttons
| Option | Action |
| reject | Revert the most recent change. |
| review | After each spring is
                                    selected, MotionView indicates which degree of
                                    freedom (dof1 through dof6) is active for the element, and also
                                    displays the appropriate values after property = .  This function assumes the spring element is active and on the screen. To make a spring element with the same degree of freedom as an existing one, review the existing element. This places the appropriate degree of freedom and property into the panel.  |
| update | Implement the changes made in the panel. |
| return | Exit the panel. |
